Tom S
- Joined
- May 20, 2011
- Messages
- 3,365
- Reaction score
- 1
It is awesome to have friends.
200% nozzles is what ive got!
Yea 320/200 if I remember correctly. I dont need that namy cc's........well thats not true! haha But what Im just looking to get at, Im still sold on a nice set of stage 2's! With 200% nozzles of course.
Croak, according to my information there is 3.5ms available at 3500rpm's and 2.9 at 4000rpm's. According to the chart below from Nate, that allows for 317cc at 3ms and 365cc at 3.5ms. I think it's safe to say you can empty a 300cc injector with 200% nozzles at 4000rpm, definitely at 3500. A conservative HP per cc is 2.4. Thats 720HP. Some folks are getting more HP per cc, some of that may be injector work like fuel side mods etc, some of that may be head work and cam, or it may be a combo. I'm placing my bets on head work, Matt's stage 2, 300/200's and compounds for 700HP.
By the way Bore, that chart you posted must have some fuel side mods done. Thats quite a bit of CC's if you compare to a regular 200% nozzle'd hybrid
True. Would be nice to see some flow charts from other injector manufacturers. Heres one with significantly less flow at a given PW and psi than Nates injector.
Well bud, not to spoil the suprise but here's a little tid bit on injectors that the guys have taught me over the last couple years...
A) mine are only 250cc with 200% nozzle
B) The nozzle dictates how much fuel leaves the injector in a injectin cycle, so going with a larger cc injector does not always mean more power, you must be able to get all that fuel out and burn it first. If i remember correctly a 200% nozzle will flow enough to almost empty a 250cc injector, if not empty it completely in like 3ms i think i read at 3000psi? Someone correct me there, i feel like i messed that up.
So that being said, if you went with a stage 2. Stage 2= 160cc with some sort of aftermarket nozzle, typically. You would not only be running the injector dry on every cycle, but it would almost be a waste. a 100% nozzle is more than enough with only 160cc's of fuel to play with. Plus its been my experience that you want some fuel left inside the injector afterwards, so if you want a 200% nozzle id go 250cc at the smallest. If you want a stage 2 stick with a 100% nozzle.
And honestly for your truck with that t500, you dont want a 200% nozzle. The larger the nozzle, the more oil pressure typically needed. a 238/100 hybrid or a 160/100 stage 2 would be awesome for you, come to think of it an AC with a 100% nozzle might even be great....seems like lots of people love them these days
Appreciate that my friend. Still learning all this stuff!! I just assumed you could put 200% on any aftermarket injector as long as you had the mods to support them.
I may be wrong but I think I remember Dave at Swamps saying he has 200/200's.
It would be interesting to see some flow numbers for the smaller cc injectors with larger nozzles though. And to hear from some of the tuners who may have dealt with them before as Im sure there are a few sets around.
I would run a 200% nozzle on my 175's if I was planning to stay that small. A smaller injection window is always better for egt's.
is why dave has small cc's and large nozzles. he's probably still using stock amounts of fuel per injection event, he's just doin it so fast, that egt's probably went through the floor.
