2015 test mule
Athens, IL
I want one. What kinda time frame till something like this is available?
I don't really know. Probably a month or two. Not going to be a cheap turbo just to let everyone know. The larger turbine models will only be built from new ford turbos. All the machining and custom parts are very expensive to do. And the machining and work to this turbo are nothing short of perfection.
KEM still doing the tuning?
Yep. Of course.
Athens, IL
If you drive your truck on a race tune all the time with a stock transmission, your going to eventually wear it out. That's a fact of life. The harder you run it and the more power it makes only helps accelerate the process.
Powerstroke Man 6.4
Morgan whats you guesstimate on power with the 68 and stock 15 pump?
