205/100 Numbers?
imelmo
For people with 205/100 injectors, what kind of dyno or track numbers are you seeing and with what turbo and/or how much of da juice?
Skinny
British Columbia, Canada
I did 570 on BDs dyno with a low reading dyno with compounds 62 and s75 little to no smoke! Once i have a trans in i will run it at the track.
bft blue oval boys
Burlington, NC
I ran a 12.7 back when I had 205/100 with a 66mm truck weighed 7100 with me in it
Did the 66 need more fuel or did it have plenty left over? Everyone seems to say that a 66 is good for over 600hp. Also, what was your trap speed if you can remember?
Sent from a Cummins plant, driving a TDI, wishing it was a Powerstroke
Pizza pig
MD
A 66 is good for 650, but will need a gate at that level more than likely and the right turbine and housing to boot. If you can hold ICP, full fuel 225cc will get you there more than likely, but it is too much fuel for a 66. So 205cc is about the walking line of being a great setup with that charger.
Josh@DirtyDiesels
PA
My buddy did high 500's (I forget the exact numbers) with a 68pmax and 205/100 swamps. Truck RIPS. Think the intercooler was on the way out then too. Know he replaced it and it is running a lot stronger but still hasn't been back on the dyno...
Skinny
Yes fuel only weak trans and low reading dyno did not help lol truck has a lot more then that in it hope to have some solid #s soon
Sent from my iPone sitting on the crapper
powerstrokedkid87
New Jersey
I'm assuming (and hoping LOL ) those are fuel only numbers, correct?
Keep in mind, that 570 with 10" of lift 38's and 24s, on a non loaded dyno, with stock 3:73s....and 13.4 was with a 2.4 60ft time, at 103 due to lack of paying attention to the tree and launching at 5psi
..........fuel only.
66 on a stock height truck with 205/100s will be 600s all day im just not one to put baby tires on my truck for a dyno numbers and track times, i like run it the way i drive it.
ncdzl
You still run stock oil?
