5r110 Limits LMAO
Pizza pig
MD
i dont recommend spraying vgt's a lot without tuning made for spray, you'll over speed it. There are plenty that do however.
its going to take a lot of spray to clean up full fueled 190's and you probably wont even clean it up completely.
imelmo
Mine was getting sprayed AND had a Procharger feeding it and it was fine. Not recommending it by any means, but it can be done.
Mdub707
Mohawk NY
Not sure. I'm about to try it with some 290's though. LOL
I'm hoping the turbo is as tough as the stocker or a 38r.
I will be interested to see how you make out. Keep us posted! (I'm sure you will)
That's kind of what I was thinking.
Silverback
I drove my stocker 90k miles with 50k miles of that being on a race tune. Installed 190s and an ssx and the clutches just wouldn't hold any more. Replaced the forward, intermediate, direct and overdrive clutches/steels with a new direct solenoid and direct apply piston. Continuing to daily drive and it doesn't skip a beat.
An a side note I couldn't believe how well it shifted on the original frictions and steels...every single friction was black. Oh and the direct clutch was shaved smooth and looked like a wave spring.
Pizza pig
MD
thats how mine were exactly, but I had 174k on it and a bad direct solenoid.
I used the suncoast clutch rebuild kit that includes all new clutches and steels, pistons, new direct solenoid, and a ford seal/gasket kit (suncoast's version doesnt include everything) and im still waiting for doug to send me back my gogo direct solenoid. I used a new ford converter with the plan of switching to a river city ultimate converter when its time for a turbo/turbos.
theres nothing wrong with doing what silverback did, all my clutches were fine except for the direct, it was TOAST. The stock converter is good for a good amount of power as it is a tripple disk design, and for $280 from the dealer plus core you cannot beat it.
DIESEL SHOP LLC.
GRISWOLD, CT
putting a BTS in a 667 hp 6.0 right now. will see how long it will last, The one we took out only lasted a few months and it was one of thoes home built trannys LOL. And it came back with a stock pan on it. Tuneing is the biggest problem with these brian says.
Pizza pig
MD
pretty positive he uses a stock pan, the deep pans on these 5r110 is pretty useless.
strokin6L
Springville NY
I was told it's still a large single disc.
chappy
Marshall Mi
Well My convertor crapped out friday. Hoped it was a solenoid but nope looks like the convertor crapped out. Looks like a stocker is going back in. Where did you find a stocker for $280? My local dealer wants $550 and a tech there says it cost $450 at his cost.
Pizza pig
MD
My local dealer, but tousley ford has it for $285 + 70 core online! I was going to get it from them, but my local dealer actually had one.
You have a suncoast converter? is it not warrantied?
chappy
Marshall Mi
I don't know if it is or not .I'm not sure of there warrenty . It Was in the truck already when I got it off Dustin (Dustball8504).
Silverback
Silverback, what would a repair like that cost a guy?
Parts are real cheap, I did all the labor myself so I was only out $150 with fluid and all, that's if you can get parts at cost. Typically too R&R and rebuild you'd be looking at around 10 hours labor.
Pizza pig
MD
Mike, i paid 2700 said and done
Suncoast rebuild kit and gaskets etc -$1100
Ford converter $285
Fluis and filters $135
Labor- $1000
Local guy on here knows his **** and did a wonderful job.
Rcd ultimate converter when the cab is off and a bunch of other parts ;)
Breaking Habits
Mapleton, Illinois
Ford converter $285
Labor- $1000
I second the RCD Ultimate Converter for the build.
Mdub707
Mohawk NY
Nope, it's a triple disc.
Ford converter $285
Labor- $1000
Thanks man. I should be good for a while, just kind of curious what it'd cost. I think a stocker will hold up just fine for what I have now, and for future plans anyways. I doubt I'd ever go over a 175-190cc injector. Still need it streetable and able to tow.
