Dieseljunkie
Ok man sounds good. Do you happen to know the part number for the bracket? All the 6.7 pumps I've looked at today only have the pumps themselves...no bracket.
I don't. If I was home I could help.Ok man sounds good. Do you happen to know the part number for the bracket? All the 6.7 pumps I've looked at today only have the pumps themselves...no bracket.
Pump is doing awesome. I'll snap some better pictures when I get off work.Any updates?
That's it. 1/2 inch lines and hose clamps.What did you use to connect the new 1/2" fuel lines to the pump? just rubber lines and SS hose clamps? Any pics of the pump installed?
Let me know if you have any questionsAppreciate the write up man, just went ahead and picked one of these pumps up to redo my fuel system.
Been on the boat for the last month. We got called up to new York to break ice in the Hudsonwhere are all the pics?
Garrett
Working on it. See my post a few posts up.Any pictures of this set up??
I made a video of the general wiring but my damn phone isn't letting me upload to YouTube.Any new updates on when the DIY write up will happen?
The fuel line runs inside the frame rail forward, then up under the intake directly to the fuel bowl. The pump is mounted inside the frame rail just in front of the fuel tank. If you want text me tomorrow and I'll send you some pictures. Then maybe I'll finally remember to post them in here.I was more curious to see the pump placement and the 1/2" fuel line routing you did. I have the general idea of what to do, but would like to see it before I attempt.
