6.7L Carnage - Testing the limits
dieselpower
Best Coast
Saw on ATS live stream they just layed down 779hp & 1661 lb ft. No breakage as far as I can see. :ford:
EDIT: laid down 845/1851 now...
WHY NOT
Carlyle IL
1851 Ft/lbs :shocked::shocked:
Edit: so what is done to the truck now? Bigger turbo than before I guess and some bigger nozzles in it?
7.3psd97444
Indiana
Dual HPFP kit. Completely stock injectors and nozzles. (long as it hasnt been changed since the first attempts.)
Single turbo kit. 63mm IIRC, gated
Dzchey21
wyoming
If that was at ats you can pretty much guarantee the correction factor is high so actual power is lower. Either way tho I can't believe the thing is still alive
Wayne
Twin Falls, Idaho
Anybody know the end results for this truck today? I drove past like 8 times today, but never stopped in. Too many honey-dos.
WHY NOT
Carlyle IL
I thought they were going to put a bigger single on it than last time since they were maxing the 63mm out and possibly putting bigger injectors in it
7.3psd97444
Indiana
I know they want to do that. But I do not know if they did in time for this event or not...
