I don't know about the kem tunes but my h&s has issues with the cruise, you have to float gears from 5th to 6th in order for it to work at all.... Then if you lay into it hard passing someone you have to turn the key off and restart.... H&S told me it has to do with the torque management system on these trucks, but it sure is a pain in the a$$!
I can do that too, but to keep it working through the entire key cycle is the problem, also, out of curiosity, what would the difference of ''floating'' 5-6 gear be? The last time I took the trans out I don't remember anything other than a neutral and reverse sensor. How does the truck know what gear it is in?
Sucks to be y'all
Sent from my Motorola Electrify using Tapatalk 2
Yeah how does it know what gear is selected? I only had a cruise problem once, it was some wack h&s update where everything else was screwy too. I couldnt live without cruise with the amount of miles I put on, I even added it to my 7.3.
My guess is because there is a sensor on your clutch pedal itself... Once you depress the clutch, it kicks it out of cruise... Therefore if you float the gears, the computer doesn't know, as you didn't depress the clutch. I don't have a 6.4, but do have a 7.3 6spd, and I'm guessing the zf6 hasn't changed much since.
I just wanted to confirm that with your H&S, you have to shift without the clutch to get it to work....right?
Nope, I just shift normally and cruise works perfect now, even with the KEM tunes.
