60/71 twins?
MorganY
college station, tx
Maybe I just want to do twins. What turbo is going to give me 5-550 and quick spool?
Garrett
probably getting paid at work to post this from my bionic
Well there are VGTs out there that can.....but the probably wont last any longer than 20,000 miles. Haven't seen a huge vgt able to do that yet
TooMuch03
West Bend, WI
Garrett
I say go for it! I would run a little bigger stick, like 175/75. There will be some trial and error getting the lp turbo spec'd out but it would be awesome. Tuning is the hard part.
Extended Power
I don't wanna piss on your parade, but I would like to know why you would go through all the work of fabricating up a set of twin turbos to get 500 hp, when you could get the same HP with a single VGT?
Again, just wanna know...not trying to be a dick.
Extended Power
And I think a VGT in a twin set would work fine if you don't spray the hell out of it.
Compounding is actually easier on the secondary turbo, then running it as a single.
(eg: 80 psi on the backside of it pushing one way, and 35-40 psi on the frontside...only about a 40 psi differential instead of the full 80 psi runnning as a single.)
SSpeeDEMONSS
6mi from the beach, SoCal
Why not? If I do twins it wouldn't get sprayed.
When one of my other engines gets here I'll see what I start to do. Might just go stock charger and fab the twins in what little spare time I don't have.
Garrett
SSpeeDEMONSS
I assume a 180/75 would be a better injector choice? Though still curious how far a 155/40 could go with twins.
Garrett
Fast-6.0
Alamosa, CO
I have had this on my mind and have been thinking of using the VGT from a VT365.
Its a 54mm inducer with a small turbine wheel. Combine that with a 71. Why? Because I love the torque a 6.4 delivers. Wouldn't be as much torque but would be pretty good.
FaSSt9602
Gilbert, AZ
Why not a 72? Your new 72 seems to be working well...
05PSD
Bremerton, WA
I'm interested in this too. I would like (if possible) 450 to 500rwhp with an ultra strong low end and mid range for towing 12K. I like the idea of small twins for getting my loads moving quicker.
SSpeeDEMONSS
i assume it has already been tried but can the secondary be turned sideways? enough to where the up-pipes would go straight forward into the turbine housing and the downpipe would come out straight towards the passenger side? i don't have a complete engine in the truck to look at but i will have 2 in the garage by the end of the week that i can play with.
Garrett
Spectre32
Why wouldnt the torque profiles be close to the same??
