RedRice589
Are there dyno sheets with these overlayed? It would make this much easier.
Does the streetmax come up slow enough to smoke before it lights? I wouldn't want any more smoke than I get when I step on it with my stock '11 turbo
Since I think I have the most time with a billet 61mm I'll come in here and say there is low end smoke to deal with. It's not hard at all to drive around. I need tuning revisions I have not gotten yet though. I'm running canned tunes because I haven't gotten with gearhead. But it will puff and then clear up 100%
Not exactly sure how much time MikeS has with these trucks with big chargers, but KEM has dozens of hours with my 11 w/ a 61mm & Morgan's 15 w/ a 64 live tuning and dialing in for driveability
I will say any 11-14 truck with even a stock turbo 15 retrofit can benefit greatly from custom tuning. Mine has a powerband like a race tuned LML, only cleaner, and stronger
Agreed. Mine pulls all day long and gets driven hard everyday. It made all the difference towing and WOT. He'll even in town it lights fast and pulls nicely but not too much you have to let off.
Here's the problem. Your getting input from guys that flat foot ALOT and are big HP boys in general. Alittle lag doesn't mean much to them.
If your looking for an easy smooth transition the 61 will be your best option. Whether you go billet or not.
I like the 61mm I have but I'd also go for the 64mm now that I have it and I trust Morgan to say the 64mm spools a touch slower. Mine lights fast.
Ok, let me make this very clear. Any time you go from a stock 11-14 charger to any 2015 charger there is a big dead spot down low. That is not the turbo. That is the tuning. The 11-14 vane control is way off with a 2015. Can you drive it, yes. Will it be anything like your stock turbo, no.
With tuning we change the tables to mimic a 2015. When that is done they spool as good as a new 2015. Which if anyone has any real seat time will tell you does not spool quite as fast as the tiny baby 11-14 turbo. But it's way better than even a 6.4 with stock chargers.
The 61mm TowMax spools better than a stock 2015 charger. The StreetMax is a tadd lazier. Even with a 1410 pw race tune it was nearly impossible to make the StreetMax smoke. It is still a small turbo. On a 6.7 you are talking a 100 rpm difference at best over stock. So stock starts making boost at 1200 this makes at 1300. I could make 15 psi at less than 1500 rpm with the 64mm. I don't think spool is an issue. I'm picky, very picky about what I drive. You talking about slighty modified stock turbos. Not s400's... Spool is very very minimally affected. But to get best results vgt tuning to mimic a 2015 is a must for any. Has nothing to do with the compressor size of the turbo.
I would make all my turbos StreetMax but I have the TowMax as a cheaper lower hp turbo just to give guys a nice alternative to the stock cast turbo. It's not really a driveability difference. It's a power and cost ratio more than anything.
So please, understand I am not a "big power" guy. Don't ever say a non vgt is so great to drive. I would take a 64mm over an s300 any day of the week. I've done a lot of this testing to try to help you guys with real world scenarios. I have no issue sending my 80 year old grandfather out in my 2015 or my wife who knows nothing about trucks or how modified ones drive. I never turned it down. Never changed the tune. They drive so close to stock that it's not an issue.
Just letting you know the real facts from someone who's not guessing. I know them both because I built them. I've drove them extensively. They are both good turbos. If you don't really care about max power but would be satisfied with a nice hp bump and the added reliability then go TowMax. But for the person that wants to run with hot tuned 6.4's I would say 100% you need a StreetMax and a bigger pump than a 2011-14 has. That's gonna get you 600hp 6.4 type power with a big tune.
There's no little faces so I cans stick my tongue out at you. LOL :hammer:
not sure how you'll ever know if you like a set-up without driving or riding in a truck with it, but maybe these videos I just shot can give you an idea of daily driveability?
Truck is ccsb, 4x4. 3.31 gears, 35.1" tall tires, 2015 turbo, stock 2012 HPFP, stock exhaust with delete pipe only, no limit cai, egr deleted, GearHead tuning
Minimaxx parameters shown are: boost - egt - pulse width - throttle position
Locked in 6th at ~70mph just to show responsiveness. While I'd love to go 100% throttle for you, I like my rods
http://youtu.be/EVDYVx8ZMmQ
normal stop light start with traffic flow 25-35% throttle max
http://youtu.be/YDBZoRpYT8M
rolling stop light with traffic flow 25-35% throttle max
http://youtu.be/MzwSTH89idc
simulated kick-down pass at 60mph 42% throttle max to get it to drop a gear
http://youtu.be/TNDsfzN5GH4
Floor it in 6th candy azz... I've done it with 17k behind me.... Locked in 6Th on HOT lol
This is pretty much the issue I've had all along... There doesn't seem to be any consistent opinion on what the right turbo would be. I haven't driven a truck with either turbo, so I really have no idea which way to go. The cost difference from the 61 to the 64 isn't much, but making the wrong choice, and having to buy the other after a while would suck.....
64mm!!!!!!!!!!!!!!!!!!!!!! Nothing wrong with either... And I have 30k on mine already.
Alot of good info. in this thread........
Isn't it past your bedtime grandpa...??
The billet 61 sounds like a great upgrade, but is there really much to gain when running a mild tow tune? I'm tuned and deleted and pull 15-18,000 with my dually on 35's (3.73's). I can see the obvious gains when you're maxing the turbo out on a hot tune, but is there much benefit for my application? Will it move enough air to let me run more power and keep EGT's in check or am I simply upgrading from a reliability stand point of not having a failure prone turbo?
I'm still on the fence whether I should do gears (4.30's) or the turbos.
Turbo turbo turbo. For you I'd say 61mm... I wish you were closer I'd hook my truck to your trailer and hand you the keys.... And I'd say that to any one of you that's concerned. Put 20k lbs behind my truck and take it for a spin.... Even on no power it pulls strong and never falters. I run one bump up just because I can. And it's awesome.
