'76mm Tow power-X ???
bft blue oval boys
Burlington, NC
JD, what are/do you think your track times are at sea level with that setup?
All of us are bugging the **** out of JD. Lol
Sent from a Cummins plant, driving a TDI, wishing it was a Powerstroke
jdgleason
Fort Collins, CO
Jd, you think the added fuel helps drive that charger? I'm wondering how it will react to stock fuel and the factory vgt
Not really to be honest. I mean any time you add fuel it drives turbos harder, but it lights so effortlessly it's awesome. I really don't have a ton more fuel, and I would bet a lot of guys run a bigger pw tune than I do... I'm confident that it would still be super snappy with stock fuel.
Plus - I've driven stock fuel trucks with high powers and they light just as easy.
jdgleason
Fort Collins, CO
Just guessing....... But I'd say .7 -.8 faster at least. Dzchey21 raced his truck at bandimere, then in Texas and I wanna say it was right in that range. When I went to Phoenix (1,600') I ran .6 faster.
code3f250
This thread has been extrmely helpful thank you everyone for all the replies! I think Ill be going with the jr. highpower. It seems to make great power, have great sound and be able to run on stock fuel just fine. Now to search for the studs and right wastegate....
08BIGRIG
WI
JD can help you out with all of that.:gun: He has a S on his chest.
B585Ford
WV
Pertaining to the OPs original question, if he went with the Tow X or HP atmo only, what we be needed to make this work with the stock VGT (or a drop in 59 VGT)? Would it require your own fabricating?
Wayne
Twin Falls, Idaho
A whole crap-load of custom parts. machined pedestal to accept a custom oil drain, custom oil supply, special down pipe flange if the turbo doesn't come from elite, same intake as the Jr. High Powers, custom turbo to turbo boost pipe with provisions for the fuel cooler. At that point, you just need to order the tow-x minus the vgt.
To the OP, if you're sticking with stock fuel and VGT, I think you'll be very happy with the 72. It's actually a 72.4mm. If I were on a fairly tight budget, I'd to a 72 and z-max jr. intake manifold. If you don't have an upgraded passenger IC pipe, that would come early on the priority list. Adding the vgt drops back pressure, and also adds power, as well as drops EGT's, so don't count it out. It's just a higher dollar item. When i ran the tow power plus compounds on stock fuel, it ran fantastic, and I really don't think there's hardly any more fuel to burn when running that combo. I also don't think think you'll be disappointed with the 76 by itself though, so take it for what it's worth. I do love mine, but I have the whole jr high power package. I guess my point is, that as amazing as the 76 is, I wouldn't plan on it unless I planned on the VGT as well. That's just personal preference based off of a lot of testing a lot of combos. Everything balances out better that way.
I wish I was still testing turbos, or had the means to do it up here in the oil field because I would love to test that 73 mentioned above. I tested a 75 cast wheel at one point, and it was pretty much on par with the 72, so it goes to show how wheel efficiency is a big deal, and smaller wheels can out-perform larger ones if the engineering is better.
