95 fummins
not enoughsmoke
lynnville tn
Sneak peak
markfuga
Leesburg, VA
Nice build to date, but that 4 link setup is scary looking; not at all how I would go about attaching to the frame. The frame mounts should be fabricated brackets that bolt to the frame, not welded to it. The way it's setup now, those welds are holding all the dynamic loads at the lowest point of the frame where they will fatigue and fail. That peice of square tubing appears to be 1/8" wall at best which is undersized for the task. Again, the design is poor and should not use square tubing at all. The welds are poor, very ropey, cold and apprear to have little penetration on the frame side of the joint. I seriously recommend cutting those brackets off amd starting over. I can't see enough detail of the axle brackets to comment, but the one weld I can see looks cold. Safety is paramount and the suspension of a vehicle should not be taken lighlty.
not enoughsmoke
lynnville tn
The four Link is being done by a professional and it's not even close to being done. He is putting more gussets and more bracing. I didn't want it bolted also have you ever looked at the four link setup on the front of a dodge it's all welded and a lot cheesy
OuchThatHurt
Neah Bay Wa
Brotha! just want to say thanks for all the pics and info you have been giving us. Been thinking about a cummins swap for years.... and your just making me want to do one more and more!
not enoughsmoke
lynnville tn
more of a update got the truck home and for those people who say lifted trucks cant tow Suck it lol
I then pulled the bed and started cleaning the frame up
not enoughsmoke
lynnville tn
Where's your trac bar on that rear axle?
The rear bars are triangulate so the guy that did the work for me doesn't think I will need it.
he did build it and give it to me. After installing it if it is at ride height is sits the axle straight if it's taller or shorter it pulls the axle one way or the other so I am gonna play some more with the design. Any suggestions?
08strokin
Maryville TN
I don't believe there is enough triangulation there. I would definitely put one on just to be safe.
TrailerHauler
Michigan
This ^
I noticed they had a "triangulation" to them but it doesn't look like enough to keep everything straight running down the road in my opinion. I really have no suggestions, nor am I a suspension guru, I think I could put together my own air ride with the bit I do know but I'm probably not the guy that should be giving others suggestions. LOL
I just noticed in one of your pictures that it looked like the base of one of the bags wasn't lined up with the top from a side to side view, might just be the picture to.
Also a triangulated suspension shouldn't move the axle from side to side when the ride height is changed, but a trac bar would move the axle from side to side when the ride height is changed (If I'm remembering things correctly).
