Mike For Mayor
- Joined
- Nov 17, 2011
- Messages
- 144
- Reaction score
- 0
Well im taking the alternator and starter to AZ to br tested and im going to pick up a cam sensor while im there
Ok so problem solved.. here's what happened..
Days before I installed my chip my ac compressor pully burnt up its clutches causing it to lock up .. causing my truck to not crank over.. I noticed this when I took off the belt and it worked then when I put it back on it wouldn't do anything .. so words of wisdom check your belt and pullies!
I never touched the harness just removed the e brake and slid the chip in.. I have checked every fuse they are all good and I have checked the battery terms several times and cleaned them
