OSCS
Making me want to buy a short block and build it in the garage.. Anyone have a line on one?
I must have missed what was funny about the block cracking from that exact scenario?? I never said it was the cause either, I'm just saying the picture doesn't look to good
Ahhh.... Better catch up on the two threads grampsoke:
Blocks crack from the pan jobs done improperly all to often
mmmkay.
do they usually have dents from the inside out also?
Lol
You think block cracking doesn't happen from improper installation and prep, I've personally seen it a couple times with my own eyes and others have experienced it as well. Not gonna argue with you. Stress fractures in the block certainly can't help with the life of an engine seeing power and anybody who thinks otherwise is a fool. Never said it was what bent the rod. Hope that clears up the confusion....
All you really have to do, is blow the pan bolt holes out with compressed air to make sure theres no goopy sh!t down in the holes, make sure there is no silicone on the tip of the bolt, and when you put the pan on it doesnt spooge out over the bolt holes and then go in the thread as you put a bolt in. simple :shrug:
I'm "new" here...does Absolute Performance build motors? Did you build your OBS 7.3 truck or did a shop? Have you/yourself removed/reinstalled a 7.3 oil pan?
Looking to start a motor build, and want to know who is giving what advice.
This oil pan rail fracture.....seems like an important detail.
Thanks.
Yes pull the engine!!! Anyone have weight specs on stock forged Rods?
