Before........and...........After....
Extended Power
what happened to the fan stator? Did you go to an electric set up?
Yes.
Moved the transmission cooler to the back of the truck, and added another external filter, and electric fan to it too.
powerlifter405
Butt Town
Does it work well enough for DD? I'd love to get rid of the mess in there. I can only pray I don't loose a belt during a road trip.
Extended Power
Driving on the hottest days of summer are not a problem.
Anything over 50 mph, and I'm sure the fans don't do much, as there is probably way more air being pushed through from the speed of the truck.
I kick the trans cooler on right away, but it still runs through the rad as well, so it probably helps take some heat from the engine as well.
