Berman's 7.3 build
Yea bp is one of the available pid's on the cts. I use it too. It's absolute (think that's the term) reading though. Whereas boost is gauge pressure (ambient atmospheric pressure isn't measured) . You have to subtract atmospheric pressure from the bp reading for it to make sense.
dsberman94
Pennsylvania
If your bp sensor is ****ed the cts will show 18 psi all the time.
It definitely doesn't do this. I'll mess with is tomorrow and watch pb along with boost and I'll mess with the wastegate when I get home tomorrow. How do I know atmospheric pressure? Thanks for you help Ty and jake.
Atmospheric pressure is a constant unless you live at altitude. That's what effects guys up high.
Just as if you dug a hole 5k feet deep you'd have close to 30 psi of atmospheric pressure plus whatever forced induction.
dsberman94
Pennsylvania
So atmospheric pressure is right about 14.2 give or take a couple decimals for the slight elevation.
No its 14.7 at sea level. My phone keeps changing it to 14.2. I turned swipe off and corrected myself. It's literally the weight of the atmosphere.
I don't have the foggiest idea what it's like at 5k feet or 10k feet. No clue.
dsberman94
Pennsylvania
I'm too tired to figure out the math now so maybe tomorrow I'll get a few minutes. I sometimes enjoy doing stupid math like that. I'm curious as to what it is at my slight altitude and at higher elevations like bandimere and at low points like Death Valley. Ill do math and research tomorrow because I'm curious.
backwoodsboy
Merica
The fundamental equation is:
P = Po + dgh
Po = atmospheric pressure at sea level (101 kPa)
d = density of air
g = gravity (9.8m/s^2)
h = vertical distance in meters
This is skewed, as air is a compressible fluid. As such, density is not constant. You can use integrals though.
They more direct approach is:
p = 101325 (1 - 2.25577*10^-5)5.25588
where
p = air pressure (Pascal (Pa))
h = altitude above sea level (m)
1 Pa = 0.000145037738 pounds per square inch
Or you can do what engineers do and look at a table:
http://www.sablesys.com/baro-altitude.html
swinky
Eastern, Nc
P = Po + dgh
d = density of air
where
Just shut up now you're making me feel stupid.
2000wa250
You have your tables and flow charts...everyone else has Google...
dsberman94
Pennsylvania
Haters gonna hate!!!
