I'll take some time to update everyone on the reports I've gotten from Jared the past couple days.
Truck sounds and runs great. Makes 40lbs like it's it's job. Drives absolutely awesome and spools just a hair slower than a streetmax. Puffs a bit from a stab. Surprisingly quite in the cab. Can definitely tell it has added frictions in the trans and shifts firm. Levi found driving it home on some hills that with the 3.31s and 35s it wants to bog down in OD. So went ahead and pulled the trigger on the 3.73 swap and will continue to fine tune it. Also was pulling to the right, I believe from the shop that installed the ALAs originally, so it's getting the tires rotated, rebalanced, and new alignment. Also putting some new sensors in to read boost, back pressure, etc since the oem ones start to skew around 35-38 psi. Will only help with fine tuning. Other than the couple finishing touches the truck is basically done besides changing out the break in fluids. Jared says even with the 3.31s it feels like 650+ all day.
