BUILD - RCD Longblock/Elite Single
WhiteMamba_Scorpion
All I can say is when I ran Tadd's 106 Tune for the first time after switching away from a VGT I saw Guardrails out both my left and right side window and there was only one Guardrail. LOL
Lol as long as she stayed between the ditches that's all that matters!
Tadd doesn't play games with his tuning. If you ask him for more power, he will make damn sure thats what you get lol
Haha sounds good. I told Jared I want a KILL tune so hopefully he relayed that to Tadd.
Breaking Habits
Mapleton, Illinois
Agreed. After spending a few days with him in Denver before DPC, seeing what he was able to help me figure out with my truck, and also seeing how well Tamara's truck performed with this almost exact set up, it was a no brainer
Pete's truck runs so damn good its not funny, its not winning any horsepower awards, but it is super strong, clean, and drives awesome.
WhiteMamba_Scorpion
Levi should be testing out the new trans tune from Tadd tonight or tomorrow to see how it drives so he can relay info back to Tadd. Truck has less than 100 miles on it but so far so good just the few extras I added towards the end of the build to wait on.
3.73s showed up today so hopefully getting those installed tomorrow. Excited to see how it drives with correct gearing. Also the EAS 12V kit for the CTS should be there Wednesday along with the EAS 0-100psi Pressure sensors. Should be pretty tits when it's done so I can run the CTS and Minimaxx at the same time and have more precise data. It'll work perfect with the CTS mounted on the left dash for my main monitoring and minimaxx tucked out of the way over the rear view mirror since I'll mostly just use it for changing tune.
Looking like a very strong possibility of completing the build and being able to pick it up next week. I told RCD not to rush anything on the build so it's 110% when it's all said and done. I'm a firm believer in doing it right the first time and so far so good.
jcain
Keep an eye on the obd splitter/minimaxx. Quite a few people have had the mini act all kinds of weird when 2 devices shared the obd port.
WhiteMamba_Scorpion
That's why I'm putting the 12V kit on the CTS... it will not be plugged into the obd port. Only the minimaxx will be plugged in. I'm running power directly to the CTS and monitoring EGT, boost, back pressure etc with the sensors from Edge.
jcain
Sweet. I dig it. I need to look into that setup. Thanks for the links.
jcain
How many sensors will you be running? I dig that it can do logging to csv. Biggest downfall on the mini bar none is no logging.
WhiteMamba_Scorpion
Probably just boost, ebp, egt. Not sure if it can do oil pressure. If it's possible that would be nice instead of having to do an external mech guage.
jcain
Where's the right place to order all this? is the new cts 2 compatible with all the EAS stuff? I think it is but Edge site is kind of all over the place.
Black AOD
Ohio
Yes it is. I'd bet any vendor on here could get it for you. Morgan or Mike D. Or Pimp Daddy Jared would be my first picks
