cbf9703
- Joined
- Mar 1, 2014
- Messages
- 5,596
- Reaction score
- 0
Looks amazing. I hope to see it at TS!
:whs:
Alright guys just thought I'd check in, truck is running great, haven't driven it a ton but I've just turned the key and go.
One thing I did learned recently ... Summit fuel cell foam isn't diesel rated! Came home from a drive last week and fuel pressure was down around 3 psi.. I sh#t... Had a spare filter so I started their, swapped that and pulled the 100micron prefilter apart, it had a good amount of blue junk in it.. Cleaned it, drained the tank, pulled the remaining foam, flush the tank and lines and put it all back together...
Fired it up and right back to 8psi. drove it all day today and ran perfect so I got lucky!
Also I got a new tune from Matt, Trans didn't like the 3-5 once in while, shifts and locks a bit sooner now, looks like he nailed it.
Also I bought a second bottle today for backup, a purge kit and bottle heater. Don't plan to spray it to hard ( don't want to pull a Jared and have a compressor wheel say hi with only one gate lol) but I think I've got it setup right to reduce the chance of issues... Also bought a pair of 235/65/17's for the front which I'll put on the factory steel wheels.. Not the most stylish but I'd rather it work well on the track
Soo I've got some wiring to do over the weekend but looks like we're good to go for TS, see everyone down their in a couple days!
Also what wire do I tap into on the pedal for throttle position? I'm going to run all the nos from WOT
I had trouble with TPS activation on my old 6.0 truck. Opted for the tried and true microswitch under the go pedal. Kept it simple and had no issues. Can't wait to see what it does at the track! Give it hell!Also what wire do I tap into on the pedal for throttle position? I'm going to run all the nos from WOT
Sent from my Note 4 using Tapatalk
Even better.I'm pretty sure the fancy controller that came with the kit should take care of all that once I spend some time programming it. I plan to run it on a time delay with a wot switch
