Derek@Vision Diesel
Okay I think i have checked just about everything I can think of.
Truck has a slightly longer crank time, warm and cold, ever since i went to big oil. Talked to the owner of the pumps previously and he never had any issue, so i dont believe it has anything to do with the pumps.
I have changed IPR and ICP, same problem.
Truck has probably 1000 miles on it and the problem has not changed at all. Takes 4-5 seconds to fire when its cold and 2-3 when warm. It used to fire right off pretty much right away whether hot or cold.
Could this be an injector issue?
I have AE and a scan gauge and the ICP is just flat out not coming up fast enough, it slowly rises to 350-400 then fires off.
