Derek@Vision Diesel
Who's tunes?
Tony Wildman
Anyway else have anything I could maybe try?
Who's tunes?
thamks for the insight!!!!! That seems like whats going on here, definitely weird though!I had the same problem on my 97. I put a modded 17 degree pump and was getting extended crank times when cold slightly extended when warm (hardly noticeable but still longer than normal) I put my stock 15 pump on and extended crank went away. Btw, previous owner of modded pump said it didn't cause extended crank on his truck do I also had it checked by a company that mods pumps and it tested good. Just saying...
On a side note, by then I could swap pumps in under an hour.
Not sure if I or someone else suggested this earlier, but have you tried running a known good stock pump? I've a pretty good idea what's causing the extended crank.
Did you swap out the injectors yet? Have you checked the IPR/IPR 0-rings?
man bunch of ide's here....
Stroker... have you tried to pull tony's chip and see if it starts better?
you do not have a pump issue, they are not "bleeding down" if the res is 3/4 full... IF the rails bled down that is an injector issue, not pump related as the rails will not be emptied backwards through a reservoir that is higher than the pumps....
pumps are not rocket science they pump or they don't... yours by all your postings are pumping....
The day you started it and puffed black smoke....it was colder that day wasn't it.....
you need your tunes adjusted, your problem only came about because you installed the pumps and it amplified an already existing problem....
how does it start after you have drove it around for a bit and got it warm, or when you plug it in overnight?
Jeremy, I think Frank was asking who was going to do the live tuning.
I do believe Derek has this issue no matter whose tunes he is running, I know he has mine, Beans, PHP and not sure who else.
I will pull the chip this afternoon and fire it up.man bunch of ide's here....
I have Beans, PHP, TW, Cale (tyrant), custom files from up north, a couple ive tweaked myself etc...Jeremy, I think Frank was asking who was going to do the live tuning.
I have changed injectors within the last 50 miles, i went larger.And take it FWIW I am not bashing your tunes Tony....
These Obs trucks (as I am sure you know) have WAY more fueling in the stock files than a comparable superduty... remember they were set up with 90cc injectors... then you put in 3 times the fuel and wonder why it is long to start... needs more heat in the cylinder to fire all that extra fuel.....remember ol' Trubbs making 400 in a stock file...hmmmmm lol
What I was getting at is he is having the same issue most OBS guys complain about....
Have a hunch bump timing, lower fueling and the truck fires right off....
if the pumps make 3900... they are working....
Joe has no clue, problably has no idea what is going on internally in the pumps... and would bet a thousand dollar bill that could'nt explain how they could "bleed" through the pumps if his life depended on it...
really hate to see a guy get all this bs info, swap "parts" instead of dealing with someone with a little bit of knowledge, and finding out what the problem really is...simple fix that way.......
FWIW my vehicle twin pumps, tuned for stock pump, and Farmers 200%sureflows fires right off everytime....unless its cold....and it aint a GP system problem.
