correct...
for the most part i get it...let the small turbo take care of the spool up from the start and then let the big turbo do most of the work up high to move the bigger volume needed
My 110's were very smokey with >20K FRP. It's amazing what an extra 5k PSI will do,
Sounds like a serious build. Lots of turbo threads going on in PSA. I'm looking forward to some results.
Dude, just go the fuel pressure route. If you want noticable power, add a second pump. You may see less smoke also. I do not see the point of doing all this turbo work when you cannot maintain FRP.
:whs:i think he is planning on more fuel too. he probably wants to clear 110s with a big tune... more than 1.92ms of pw...
Im pretty sure josh is going to upgrade everything to make it as smoke free 600-700 or 800hp as possible. I dont know 6.4 stuff at all as im a 7.3 guy, but josh and i were talking over the weekend and he sounds like he knows what to do and what he wants, except for the whole turbo ordeal.
screw 600...im only like 35 hp away from that now:biggun:
Your probably closer than 35 horsepower.
probably...thats what Dunbars dyno gave me at TS 10..and i dont wanna throw out some random number that might be higher with no proof to back it up
