Compounds
Skinny
British Columbia, Canada
Still got to look into waste gates i like how yours is. going to the shop in the next hour see what they have in mind. Seems like there is a real science to what charges to use injectors waste gates my brain is already mush .
TooMuch03
West Bend, WI
Does Kevin's setup have the internal gate functioning as well, or is that disconnected so it's always closed? I would think two gates would be pretty tough to setup.
kevin
springdale wa
Unless your going to spray it I wouldn't worrie about an external gate ... Mine stays blocked off unless I'm at the track spraying it
BlueWaffle
Grapevine, TX
I'm fixing to pull mine off and cap it also......until I can be convinced to put some gas on it. as it sits, i just have manifold pressure holding the spring shut.
BlueWaffle
Grapevine, TX
Meh...the HP is pretty small on the turbine/housing side. might need to but I'm sure someone who knows more than me will chime in...
Pizza pig
MD
depends if the exhaust housing youre using is internally gated, if not, than you will need an external gate to keep surge and drive pressure in check.
MorganY
college station, tx
Keep us posted with photos if you choose to go through them. We have some of the most knowledgable 6.0 guys on here who can give feedback.
My buddies compounds were a horror story, there's more to fab'ing a kit than one would think.
smokinstroker
Texas
horror story is an understatement
the 62/65 over a 475 was a great combo for 205s
Skinny
Will be running my bd turbo set up for the hi pressure it's a 62/65/70 internally gated turbo and will be running a s475 with PDR's updated up pipes guys have lots of experience in building twins for cummins this will be the first twin 6.0 in bc that I know of. Thanks guys for your info and I'm sure ill be asking more!
Extended Power
Make sure you have an external wastegate installed...the small...even after opening them up internal gate ports, will NOT control the drive pressure...
Redneck6.0L
if you use a 62/65/70 t3 with over size internal gates and a s475 you WILL NOT need a external gate, Ivan has never run that setup so his informaton is not accurate. for where you live and pulling the mountains this setup will run good for you
Pizza pig
MD
You should be just fine with that charger. I cant remember the size of the gate ports on the thruster 2, lemme see if i wrote them down somewhere. I know two people with that charger in compounds, one with a 475 and the other with a 474 lp. Both dont have external gates and dont have back pressure problems.
kevin
springdale wa
I know you have had some crazy back pressure issues and im not sure why lol... But with my setup iv never seen over 65 psi of bp fuel only with my external gate unhooked.... I think you just have all the "luck" Ivan LOL
