Compounds
smokinstroker
Texas
Remember alot of guys are running the vband .70 housing. If you go to a straight t3 that should help as the factory flange is restrictive
smokinstroker
Texas
Sorry I should have said running a t3 with new up pipes that are t3 in theory should out perform a t3 turbo with the vband adapter with factory up pipes
Pizza pig
MD
Could also run a reworked collector on the stock and run the flange still, but bored out the flange to make it flow better.
TooMuch03
West Bend, WI
A little off topic, but what do you guys think will spool faster, a t4 divided .83 or a t3 open .70, assuming both have better than stock up-pipes?
FaSSt9602
Gilbert, AZ
My vote is for open T3 .70.
I have a 62/68 sitting in my shop right now with both the open T3 .70 and divided T4 .83. If I do the compounds here soon, I will be going with the T3...
FaSSt9602
Gilbert, AZ
All accounted for, housing was almost $500 more for the gated, I can get a better external for way less than that...
FaSSt9602
Gilbert, AZ
max 205 injectors, seeing how your in the mountains of bc, for your large turbo i'd do a s475/83/1.25 t4 some on here will say that exhaust size is small but if you mount the second turbo on the passenger side were the battery is, the velosity lost from the long intermidiate pipe is huge, i ran that setup on the dually when we towed my race truck over the coke between kamloops and mission. you'll be happy
Shawn, where can I find this turbo? I can find it with a T6 all day long, but I found one place that had it online and it was outrageously expensive! Is that just going to be the cost of making good workable power or could I get by with a 475/83/1.10 T6? Or is there a more "standard" size that would work?
Pizza pig
MD
I can get that turbo, but im not a sponsor yet, hit up Matt @ Cutting Edge Diesel, He can get it for you.
