Compounds
TooMuch03
West Bend, WI
this is what I have read on here multiple times, im just saying I personally have never seen back to back tests between the divided housing and a t3 open. (saying comparing a .70 t3 to a t4 .83 divided)
I would love to see a comparison like this. Take a truck with a given turbo, and just change the up-pipes and turbine housing, nothing else, not turbine wheel or compressor wheel, and compare how the .70 t3 open with decent up-pipes compares to the .83 t4 divided with divided up-pipes. Oh and do it with realistically sized injectors too. No offense to the guys at MPD, but the majority of guys won't be pairing 265s with a 62mm.
kdogg85
My 6.0 had a 364/475 with 205/100's on it and I could do anything i wanted. I would loved to have tried an .83 t4 on the hp side, but mine had the .76 t3 divided and it worked great. The best thing I can tell you is get the 1.32 97 turbine on the lp side. I started with the 1.10 87 and the difference in bp between the two was pretty big. It would run 1-1.03 up till 48psi and the bp would climb in a hurry, the 1.32 97 would stay 1-1 till around 55 psi and then bp would climb, 55 psi is where I set my gate to open up. The gate is a pain at first, after a couple tries you get the hang of it.
Skinny
British Columbia, Canada
Talked to JJ today Reg return should be in my hands next week and injectors following week.. Havnt done anything with the truck its parked at the shop..
