couple 6.7 questions
Traction bars will help the shudder off the line for sure. I wouldn't do sulastic shackles. The hop at 70 could be tires out of balance or out of round. The typical ford hop is 45-55mph. You could have a driveline shop check pinion lash in the rear diff and check to make sure you don't have a bent axle.
FlatbedCowboy
I dont think its bent, Im going to have the tires (Japanese knock offs) road force balanced. But I am thinking its more like the TSB 16-0087 for adding the dampener. It may be more at 45-50 mph but I dont spend alot of time at that speed :lookaround:
What PSI do most people run their 35" tires at? The only thing this truck will do is tow so Im thinking 40 psi.
ckrueg
Belding MI
If your load per tire is near the max rated load of the tire just run them at 65. I rarely tow heavy so I run mine around 40 in back and 55 in the front
