Creampie Build
BlueWaffle
Grapevine, TX
do you guys think a negative 44 offset would work? I'm not scared to bust out the sawzall and do some cutting... but I also don't want it to stick out too far and look retarded
powerstrokin15
Charleston, WV
black. and I wouldn't go 22s if you couldn't get a decent lip.
you could do 22x10.5 bmfs... -25mm. would look great imo
Sent looking at my blown up 6.4
ford rules
Lance has the truck. Says its super clean.
Got his fuel system done. I'm heading down tomorrow to start the build
Nice setup, care to share that other baldwin number? I assume your pulling through the fuel/water seperator and pushing through the filter.
Great looking truck, always loved the look of the blue waffle!!
Skinny
British Columbia, Canada
I know this might sound stupid but what about 22x10 or 20x10 front then like a 12 wide rear give it abit of a drag car look...Depending how far the rears sit out..
Sent from my iPone sitting on the crapper
Redneck6.0L
Loving the short bad reg cab. Its gonna roll, Ben Gollon got a 2wd reg cab to hook with leafs, 2wd and pull the front tires off the ground. Facebook him, he'll be the best guy to chat with for your chasis setup
BlueWaffle
Grapevine, TX
now I'm trying to decide between a 20x10 with a -19 offset or a 22x10 with a -13 offset. basically it comes down to do i want more lip and shorter wheel, or barely any lip with more face. I've always liked a deeper wheel but fuuuuuuuuuuu
jdc753
Norton, MA
What about a staggered setup like a lot of the cars run, get something you can get a 10 wide or the most lip up front, and then a 14 wide out back. Might have to go with American Force or another more custom builder to get that sorta setup but would probably look killer from the bag with some real big meats on the back side and sorta skinny up front.
