Custom HPOP lines
psduser1
on the road
Talked to the parker tech today. I asked him about 436, he thought that was probably close to what I'm after. He also mentioned 919, apparently it's rated for 450*, and has a stainless braid outer cover. The only downside was operating pressure rating of 2500 psi. 4:1 safety factor, of course. And Teflon inner.
He told me he sells quite a bit for "racecar" applications, maybe specialty fuels. Also rated for oils and diesel fuel.
Kinda still looking around.
DocBar
Akron, Ohio
I will be getting the local hydraulic shop to make me lines for my ipr's. Just rubber lines like you would see on any piece of equipment. I plan on mounting it on top of the ac compressor. Never thought of doing hard lines tho.
Is tha BTS set up?
hucorey
Defiance, Ohio
I sell a boat load of custom HPOP lines. I use Aeroquip GH781-6
Nominal rated at 5300psi burst at 21,200psi. 2.5" bend radius. Nominal temp rated to 260*
athabasca
St Elias mountains
Has any one done a 4 hose out on the BTS dual pump setup?
Both my pumps are out now for the serviceable plug and I
have had two pumps in the last two years puke the rear plate.
