Deranged rebuild, the next chapter
Cutting-Edge Diesel
Newkirk, OK
Matt did you ever figure out the low HPOP pressure? I know you said you were thinking of swapping the pump over to your other truck.
No time lol maybe before Ennis if we are lucky but probably not. We are going to try a lower pw and see what it does. Ether way it shouldn't be dropping any.
Got it all back together. Here is the diaper. Going to keep any drips from hitting the track!
Cutting-Edge Diesel
Newkirk, OK
pretty sure its because the duty cycle is the same as a stock HPOP not the IPR. Its so hard to get the thing right because you cant just go out and drive it on the street after a new tune like you can your truck. you only know after it goes down the track. Thats why Im planning on taking it to TSD before ennis and putting it on the dyno to get it dialed in and see what it can REALLY do.
Mdub707
Mohawk NY
I'm shocked. I would think that would be the best bet at holding it too. Does it just have stock ranger calipers on the rear right now?
Cutting-Edge Diesel
Newkirk, OK
No it has a sterling 10.5 shorten with willwood duralite 4 piston calipers. We are getting 6 pistons and playing with the proportioning valve some more to try to get it to hold since we can't get the trans brake in time for Ennis.
