PowerstrokeJunkie
Big Bore- Your math seems to be flawed. Is there exactly one square inch that the boost pressure has to act on the valve ?
This is snowballing into some serious cash blowing.
Whats the page on facebook. I want to check it out.
Most people on here forget more then i know on this topic. Im am constantly trying to learn, but some like to point fingers and laugh at people like me, which doesnt help anything. I question alot of things because i dont fully understand, thats what questions are for. I Want to build a very competitive sled pulling useing the heui system. Thats my goals in the near future.
I also believe you are going to lose a lifter.
How many failures are seen in the heads?
You guys should probably go on facebook and read what Doug is doing with this build, he's also got other stuff going on you're not seeing. I know I saw some titanium 10 degree locks that are roughly double the size of stock. Or maybe Doug can chime in. This guy will forget more stuff than some people on here will ever know.
Why would that matter? Spring exerting pressure one way, boost exerting pressure the other way. It could be 1/10th of an inch of area. That would not change the units of measure. If it is in fact flawed, please correct me by showing the correct math.
I guess I'm somewhat uneducated on the subject, but at what point do the Comp springs become obsolete?
Think about how your basic hydraulic bottle jack works and you will get the principle. One of our injectors might also be a way for you to think of this.
PSI aka Per Square Inch. Meaning x amount of pounds of force on every square inch. Lets use 100psi just to be simple. If an area 1/2 a square inch has a pressure of 100psi applied to it, it is really putting out 50 pounds of force. A 2 square inch area will equal 200 pounds o force.
Your right I forgot to put pounds in front of per, simple mistake. That was my bad. If that's not it please correct me
