Dozer Diesel
strokin6L
Springville NY
If they're RCD injectors....why not just send them back to RCD and have them put smaller nozzles on them? RCD flow tests their injectors...I don't see why you'd send them some place else. You did get a flow test sheet with your injectors right? I'd give Jared @ RCD a call and talk to him.
Josh@DirtyDiesels
PA
Most likely you're losing icp. Monitor icp voltage at WOT and post up what it is.
If you're low then...Welcome to the game of low icp.
It can be characterized by any of the following:
1) My truck orals coal
2) My truck is slow
3) My egts frequently reach 1800
4) There is now a large hole in the bed where you feed cash into every week
5) The only fix is
5a) New injectors from someone else
5aa) Reduce nozzle size or remove a shim if possible
5b) Modify your oil system (e.g. Twin Hpops or an adrenaline)
5c) Burn it
Sent from my SAMSUNG-SGH-I337 using Tapatalk
BINGO!!
Breaking Habits
Mapleton, Illinois
That was my thought as well
