Redneck6.0L
- Joined
- May 19, 2011
- Messages
- 1,123
- Reaction score
- 0
205s is the biggest you can go without dropping icp on 05 up. you will lose more power with a drop in icp than you will gain with it being larger if that makes sence.
We have a fully functioning twin HPOP kit available. It's actually a very nice kit. With proper tuning, you won't bend spool valves. The problem with a lot of the most aggressive custom tunes, including our conventional insanity tunes, is that they lie to the pcm, making it think there's not enough HPO, maxing out the system. This is good for a single pump, but with twins, pressures get too high. Our system also has a safety blow off valve, so it shouldn't get destructively high. The only disadvantage with our twin pumps is that the low pressure oiling system needs to be upgraded to properly take advantage ot the twin pumps. Every truck we've had with twin pumps over 4500 rpm's has burned rod bearings because the low pressure oil pressure was sucked too low to protect the engine. On the upside, we're not near maximizing the pumps on the 430 cc injectors. You'll never run out of high pressure oil with these. Shawn's right though, no real "need" for twin pumps below 600 hp fuel only. Not too many 6.0's ever cross that line so they haven't been a hot seller for us.
700 on fuel is doable, but very difficult. Just ask anyone who's made it. The pumps are pricey, but they work very well. With proper low pressure oiling you have nothing to worry about.
well i have the air side covered...now it's just more fuel and oil psi. I'm hoping that a stock pump would push 255's (hybrids) with no issues.
Wish I was told this when I was running them must have been why I had so many rod and main bearing issues
