E-Fuel Parts list, questions
old man dave
Petaluma, CA
The Bean's kit used both the Stanadyne FM-100s originally and then they supplied Wix equivalents later when I ordered replacement filters. NAPA also sells FM-100 style replacements.
jmsmith76
Middle GA
Thanks for the info.
Does anybody have part numbers or specifications on the fittings I'll need for the FPR? I've ordered everything except an oil pressure switch and those 3 FPR fittings. Want to make sure I have my facts straight before I order those...
jmsmith76
Middle GA
Nice setup. I've read through a ton of threads about doing this whole thing, just took me awhile to decide how I wanted to do it. I like the setup Tom S went with and I may use some of his ideas in my build.
I've ordered almost everything so far and I'm in for just under 500. Only thing left to buy is some wire and mounting hardware. Haven't decided how I'm going to mount my filter/pump assembly yet. Could use a steel plate with strut to space it off of the frame. Or I may make up a bracket similar to another thread I saw that had 2 plates to clamp around the frame rather than drilling holes in the frame. Since I'm not going with a stock pump mounting bracket, I'd like to see if I can come up with a way to use one of those exhaust band clamps. I feel like that would make for a really secure mount. But I'm still undecided on those things. Going to wait til my other filter head arrives and the pump so I can get an idea on size and spacing before I buy anything.
jmsmith76
Middle GA
Oh and I still need to buy the 3 fittings for the regulator, and an oil pressure switch. Hoping someone will have a comment on those questions a few posts back.
jmsmith76
Middle GA
Actually just realized that I forgot to ask about the oil pressure switch. Does anybody know if the Strictly Diesel oil pressure switch will work without their controller? Most of the other threads I've seen, people used a 3 terminal switch. The strictly diesel switch has 2 terminals.
Here's a link to it
MossBack
UTAH
Here's a link to it
Any oil switch that is normally open is fine. The 3 terminal is just a NC/NO C switch. The controller is just to simplify wiring. If the wire tap you use to excite the relay is ran to the switch in series it so that oil pressure would be needed to turn on the relay. That would be a fail safe if it dies or is not started then the fuel won't be on.
jmsmith76
Middle GA
Right that's what I was figuring. Just not sure what the wiring would be like on one with 2 terminals.
Here's the wiring diagram I was looking at:
m j
BC Canada Eh!
that fuel pressure reg uses -06 ORB fittings.
I think you need two -06 ORB to (-04 or -06) JIC whatever the factory lines are if you are going to reuse the factory stuff
the third fitting from the bottom of the reg will again be an adapter -06 ORB to whatever you choose to run to the return line.
I will try and flare the factory hardline to AN/JIC for a leakproof permanant clean install.
I personally will not use any npt if at all possible to avoid it, nor any hose clamps.
my efuel is still in parts collecting but you can buy factory style fittings to connect to the selector valve.
I bought a baldwin fb1311, -10 ORB to -06 ORB reducer, russell 644020 adapter for the filter out
filter in is -10 ORB to -06 JIC, from there it is a short piece of an style hose with an efi quick connector adapter (havent purchased that yet as I am still working on where I want to mount the filter and whether I am going to go to a single tank to make room for the rear 4 link)
jmsmith76
Middle GA
I've got everything ordered up and I'm going to post a final parts list and some pics when I get the time to install it, which may be a couple weeks or so. Ended up not using the strictly diesel oil psi switch because I want the pump to have power while cranking. Ordered a PS-64 off eBay for 13 bucks. It's similar to the style of the strictly diesel sensor, but has the extra terminal needed. I found a few other folks that used it as well. Only thing I have left to buy is the mounting hardware. I've got an idea in my head of what I want to fab up. I am not a fan of the giant hose loops that lot of folks have in their filter/pump mount and I think I have a way to avoid that. Also I'm thinking about coming up with some sort of skid plate for it. Not really worried about rocks since it'll be behind the transfer case, but I'm wary of having sticks or small trees pop up into the filters when I'm off road at the hunting club, etc.
old man dave
Petaluma, CA
You can use 3/8" steel brake line tubing to form the interconnecting fuel lines without the mess and are equivalent to AN-6 braided hose line. 3/8" tubing bender tool is not too expensive either. The big loops are just sloppy workmanship. The steel brake line tubing worked for me.;)
The pushlock hose fittings do not use clamps, they have different construction than regular hose barbs.
jmsmith76
Middle GA
Alright I fabbed up my pump/filter mounting bracket and sprayed it with rattle can bedliner. Here are a couple shots while the liner was drying...
And here are a couple shots of everything mocked up...
Anybody see any design flaws I'm overlooking? The gap between the pump clamps and the fuel/water separator is wider than it looks in that picture. It's a bad angle. I think I'll have room to get my hands in there for filter changing. As for servicing the pump whenever that happens, it'll just be 2 bolts and a couple hose clamps to pull the whole assembly off the frame rail so I'm not too worried about that. I mainly wanted to keep the pump tucked in there behind everything.
jmsmith76
Middle GA
My only concern is the hoses putting stress on the plastic quick connect fittings with it being that short of hose and it's not a 100% straight shot between the filter outlet/inlet and the fitting. I may end up routing the house over the top of the straight barbed outlet/inlet to make a longer piece of hose with a little more play in it to relieve any stress on that quick disconnect fitting.
should have use sweep 90* fittings and not square 90* fittings. or straight fittings and ran a longer loop of fuel line to them.... but other then that it looks good.
jmsmith76
Middle GA
Couldn't find any sweep fittings locally and didn't want to order any online cause I like to see it before I buy it to make sure it's what I'm looking for. I may run over to Fastenal and see what they got. I forgot to check with them.
if you cant find sweeps just go with straights.. just put bigger loops in the... as long as they dont kink its better then square fittings.
depends what size injectors your feeding with a single pump... think about how it flows compared to a sweep 90°.
jmsmith76
Middle GA
I doubt if I'll ever flow enough fuel to have to worry about that. Right now I'm running stage 1's. Not building my truck for high HP. My future HP goals are 400-450 so I won't be going up much on injector size whenever I need to do that anyway
