Ezlynk shows us a sneak peak.
Justin@DP-Tuner
Here is how Jody mounts his...
Using this mount...
https://www.amazon.com/iKross-Cellp...d=1470857328&sr=8-1&keywords=ikross+car+mount
Strictly Diesel
Phoenix
Not usually required in a Ford because the speed sensor reads a tone ring on the ring gear. Ratio doesn't matter at that location, just tire size.
c63 AMG
Lost of options with this mount and it's about $6.
valvetick
So you use a stock EGT sensor from the exhaust and the Ez lynk can read it? What does the sensor plug into?
I'm currently running the sct livewire with the sct pyro in the EGR block off plate.
Has anyone answered this? I am looking at running this but want to be able to monitor egt's as well. Or is it possible to throw on a splitter and run a cts2 to monitor and only connect your phone to switch tunes?
Ikyo
I replaced the stock sensor with one from the exhaust and the EZ Lynk reads it just fine. Plugs into the factory location.
oli6578
Orange, TX
I'm running PPEI *** on tune until my ****** pipe comes in and it reads egt temps now. Once ******d I have to run EGR blocker plates and use probe from exhaust. Correct? Where does probe plug into?
valvetick
2nd that haven't looked yet but are the wires long enough to plug it back in once you move the probe from the exhaust into the ****** plate? Any other option to use something to monitor other then your iPhone or iPad?
bigrpowr
<How I Fly
Administrator
yeah the wires are long enough and once on a diet , yes you'll need at minimum a blockoff kit or full removal . then just use a sensor from the exhaust .
oli6578
Orange, TX
I just zipped tied mine to the wire cluster under the dash closest to driver door. It's hidden very well.
