Best way to learn! :thumbup:
Yup....$549.00 this time around for balancing. It was more this time because of freight charges.
If you go with aftermarket rods, they should all be pretty close to the same weight.
Another must have: new flexplate, and dampner bolts...they are torque to yield...use once, and throw away. Cheap....I bought them today and they were less then $20.00.
Take your time....double check, and then check again before moving on to the next thing when assembling...
Are you going to lower compression any?
Someone correct me if I'm wrong, but you're not really supposed to just lay cranks on the ground like that right? Don't they typically build some sort of stand to make it stand vertically?
your not supposed to long term store them horizontally without support or just stand em up
You know I was told earlier this year by some of the best engine builders that that is an old myth. The reason they were stood up years ago cause cranks back before 1940 were weak and would flex, now days it isn't an issue. This was straight out of the mouths of 3 guys and the engine masters challenge this year.
What the hell do you know anyway!!oke:
I know that I am not an engine builder so maybe i dont know much, but in all honesty that sounds like a load of BULL **** that you can't lay a crank shaft on its side. I mean REALLY!?!? :slap: Its like comeon here let's use some common sense here and think about it for a minute. Think about ALL of the stresses put on these cranks when they are in the the motor running and then you are going to tell me that simply the weight of the crank by itself on the floor is too much for it to handle and it will warp. Yeah right. Unless I hear it from a reputable engine builder with some hard fast data that a crank in that condition will warp or deflect, then I am going to stick with the guy that heard it from the engine builders :stupid: Just sayin it makes sense.
Are you gonna get notched pistons for a stage 2 cam? Or just stick with a stage 1 cam?
