powerlifter405
Yup sorry "HG" head gasket......ointlaugh:
:doh:
i've typed myself stoopid before as well.:blitzed:
W/ the studs that he's runnning, he should be fine.
That looks like a blast! Whats the motor in that?
Sent from my iPhone 4S using Tapatalk
Its a corvette LS1 with a few goodies. Around 450hp. Fast enough it makes my truck seem like a giant turd lol.
This is leaving my buddies house on Sunday. Getting on it a little bit.
http://www.youtube.com/watch?v=M--J6PU7AG8
was that rausch creek? Also are you happy with the work street diesel did for you? I'm thinking about having Sean do some for me.
how did the new 71 work out?
FInal thoughts?
Sweet man. Cant wait to get mine installed. As far as tuning goes what does x-street compare to for spartan? 250 tune? Im going to be running stock headbolts and i want to be safe. If i see 50psi max boost on the street with the new turbo i think i should be ok as long as im not doing it all day long.
So far I see 50-53 psi boost with every tune from 210-310. Does not seem to matter I think the xtreme street is closer to the Spartan 275? I would think you would really be pushing your luck?
I probably am pushing my luck but if something happens than i can always go bigger. I think i should be ok though beacuse i try not beat this truck at all. A few posts earlier jeff said he was running the same tune and only had 43psi max boost on the same tune.
Your braver than me on stock bolts...of course, I had a HG fail and I didn't beat on mine....guess it was just bad luck.
I know I am not towing, but I see at least 50 PSI with the 310. As soon as I touch my throttle, I am at 40, it is unreal.
