Ford Rules 6.0 build
ford rules
Got some more stuff done tonight, gotta get bed bolts next week and get the bed and can tightened down.
I'm gonna say the intercooler is leaking a little, hopefully it holds for a while lol
ford rules
Made a little box to put any relays in I may have. Now I have the fuel pump wiring and fog lights in it.
Where it will sit, gotta run all the wires now.
ford rules
Anyone know which wire I need to use to trigger the fuel pump relay, I have a red, blue pink/black, black, black, and a tan/red.
If anyone knows off the top of their head that'd be great if not ill just wait till I get the batteries and everything else hooked up.
HOOV3R
Central PA
I'd have to see the layout of the wires on the relay to tell. The relay schematic should be pictured on top of the relay. The coil will need a power and a ground. The power to the coil would be what you activate it with.
ford rules
^right I just figured I'd ask first but ill look at the relay tmrw hopefully and figure it out.
ford rules
Figured I'd give a little update truck has about 5000 miles on it since the studs and only issues I've had was #4 injector took a crap.
Got a few parts on cyber Monday/blk Friday.
Got a mpd oil cooler relocation plate and also gonna give dieselsites HPODS a try.
ford rules
Havent installed it yet, i gotta get all my parts together for my oil cooler relocation before i install it. Itll probably be a little while before its on.
ford rules
Ya, im hoping for good results with it. Hopefully in the next month or 2 i will have it all on.
ford rules
Just ordered a set of 08 mirrors and paid $325 for them if anyone's interested they have more just pm me. They are supposed to be factory fords.
