Front traction bar mounts?
smokedout250
harrisburg oregon
I'm in the process of building traction bars. I have the bars and axel mounts figured out. I'm trying to figure out if I should weld the front mount or bolt it to the frame???? I'm hoping some of you diy guys have so tricks and ideas on the subject thanks
Rupp250
Do not buy anything from Ballistic fab, they screwed over a bunch of customers. Try Ruff stuff for brackets. My front mounts are welded.
smokedout250
harrisburg oregon
I've always been advised against welding on a frame for fear of cracking. I think I'm going the bolt on route I'm gonna use a heavy angle iron with about 4 ,1/2" holes. I'm not sure if I should run two holes on each end or run all four horizontal
Fenner408
Grinnell, IA
I bolted mine. Theres a big hole right before the frame curves up to go over the axle. I used a piece of angle and put a 5/8" bolt through the existing hole and two 1/2" bolts on the bottom side.
smokedout250
harrisburg oregon
I have seen those holes... That's a really good idea! Thanks I'm going with 3x6 angle just because I have it lol
Josh@DirtyDiesels
PA
had a set welded on on my cummins for 3yrs with no problems, and currently have a set welded onto my 05 with no issues. Can't go wrong either way
smokedout250
harrisburg oregon
I may weld my next set but this is my first set so.... I may change them eventually. The easier to get off the better lol. I think I can bolt them down solid and be strong enuff. Thanks for the info guys I'm really getting into this project
smokedout250
harrisburg oregon
Thanks for the help guys I went the bolted on route... There's a 5/8s bolt on the side... And two on the bottom
