01PSD
dont have the 139x codes available though sorry
Does it shudder or shake when you load the motor while driving it? I just went through a miss a couple days ago after installing a new motor. Turns out my UVC gasket wasn't completely plugged in, and wasn't sending voltage to one injector. You can take the IDM out and Ohm out each injector. I would start there. Its not hard to do. And this is if its throwing the "P1316 IDM fault code".
Refer back to this ^
Check your Undervalve Cover Gaskets for a loose or faulty connection.
If you haven't rewelded the x member then that would cause shaking. But it might even shake with it rewelded just cause it's not factory
Glad it is running good for you! NOW if I had good weather.....................
yup... We have snow and lots of it. Every weekend it is blowing and snowing. SO i cant get my engine back in the pickup.. I do not have a shop so all my work is done under the blue sky.
we have about 16" to 18" on the flat now. and drift as high as 10 feet. Infact my pickup has a snow drift beside it that make it look little.. had to did it out to get to the door to open it up.
I love it. Just wish I had a shop to work in!! I cannot take the heat. make me feel like throwing up.
