two springs in the gate.... its a JGS 50mm gate. If you look at the pictures. The top port is an exhaust reference, and bottom port towards the body of the gate is boost reference. Boost reference goes to the boost regulator that I have closed completely off so there is no boost going to the gate then to the boost reference on the intercooler piping. I took the gate off, with the egr pipe attached, closed off the pipe and charged it with air, gate has no leaks and is working as it should on springs alone, charged exhaust and boost reference ports with no leaks as well. With as much bp the is holding the piston in the gate shut, its not going to open. Tested the gate with another identical brand new gate and it was exactly the same. It I turn the regulator down to 32 psi of boost itll stay consistent on the gauge. Like I said boost and EP are constant and consistent. Only making 38 psi of boost.
Tested boost regulator, its good with no leaks, tested reference lines, neither is plugged or leaking. Back pressure with the vgt unplugged would still get up to 70 uncorrected once spooled up
