TXlineman83
Still won't load.
Your video sounded normal but I am on my phone, what didn't seem normal was the way the actuator responded. Didn't move then jumped. The fact that you say the rpms move normal to your touch on the pedal makes me believe that the tps is all good but something to the vgt actuator isn't right. Whether it be the actuator itself or the wiring.
Yeah no luck with the other video. It's still gonna go to PSE. I'm just going to keep looking at it until I can get it dropped off. If I can figure it out I'll feel much better about this then paying someone to fix a problem another shop shouldn't have caused.
I really wish I knew another deleted 6.4 locally I could sit next to and compare.
The sound I was referring to is early into the video. I don't know how to explain it.
I'm not sure that you would need to compare to another deleted one. I wish I still had access to the ford computer programs and that stuff so I could tell you what the vgt solenoid pins should be putting out at a given time. Just the way that moved looked weird. I though it shout be more smooth without that big jump at the beginning.
They move fairly evenly. Only become jumpy if I try a boosted launch. At which they the rpms will not raise above 1000rpm
And the sounds the motor makes at low rpm throttle sounds horrible like it's missing or something.
If you do a boosted launch, you can only get the rpms to raise to 1000? That doesn't sound good. Maybe you are lugging the motor with a bad torque converter. Or you have some major electrical issues.
No matter how hard you try it wont go over 1000?
Sounds pretty bad then to me, because holding the brakes and getting over 1000 shouldnt be hard at all
Yes. Will not climb over 1000 rpm. Kinda bounces around
http://youtu.be/MEjSOFasW8Q
That's full throttle in drive standing on the brakes. If u get what I mean
Wow, well im not that knowledgeable but id have to guess something other than turbos. Because even if it had no turbo on it, it would still go above 1000. cause my rpms will go well above 1000 before the single builds boost when i brake boost it
That's all I needed to know. Now to figure out what controls that
Your not building boost either
