Arisley
It is really good to see Mark here. Welcome to the site Mark.
Since there is no thermal bypass on a 4R100 that isn't the problem.
It is possible that the pressure bypass on the side of the transmission is leaking and letting fluid bypass the coolers. There is some flow to the coolers if the converter AC condenser is getting warm.
I have no idea how well an AC condenser will work as a trans cooler. What diameter are the tubes? Is it one tube that snakes back and forth? What is the pressure drop? Is it high enough that it is opening the pressure bypass? These are questions that you probably can't answer, but need to know to determine if an AC condenser can work as a trans cooler. Hint: I wouldn't use one on my truck.
That's about right. The E4OD/4R100 tend to run 60-100°F above ambient temperature.
and, that bypass. i thought the purpose of the bypass was if the cooler plugged for some reason, it would open the bypass
Is there a point where this rule shouldn't apply? If it's 120* out would you feel fine with the trans being at 220*?
Along the same lines, I know I asked you this before also, but at what temperatures do you have to worry about the trans running too cool and possibly causing condensation and other problems?
If it is 90* ambient, and I am running down the highway with trans temps of 125*-130* should I be concerned about it being too cool?
Is its not my cooler or coolers failing I don't want to waste 300 $. That's the Money situation .
