How to make 600 - 700 RWHP - 6.0L
imelmo
the ICP voltage should be reading correct however the icp actual pid will read very low. when testing for ICP it is a good idea to always log the voltage pid and not the actual.
What is pid? Hadn't heard that term before.
stonepusher
San Antonio
New power numbers........same setup as before new tune
592&1065 fuel
751&1277 one stage .125 jet
773&1340 two stages .074&.088
Track times to come tomorrow!
stonepusher
San Antonio
Did you get those track times?
Yes sir, sorry I forgot to post them here I posted them in another thread.
Fuel runs went awesome but was having some traction issues and early shifting issues with the nitrous. But here are my numbers:
Fuel 12.2@108 1.70 60ft
Juice 12.0@113 1.82 60ft
12.1@115 1.91 60ft
Don't have a bottle pressure gauge so not sure what my bottle pressure was at but I guess they sat it in cold water to fill it at the track bc when I picked it up it was really cold and wet, maybe this is normal practice idk never really paid any attention. The nitrous run was with one stage with the .125 jet. Just doesn't seem like this ole girl wants to hit the 11's, time for some more tweaking before Ennis.
andrewsteelerford05
Garrett county, Maryland
I Have a question about the setup that I am running I have a 2005 F 250 I'm running 205/100 injectors with a St366/74/91 non vgt turbo with a AirDog2 fuel pump Backed with a XDP sump innovative diesel 58V ficm built transmission built by Andy Warren zoodad mod bluespring mod 6.4 banjo bolts Jesse Warren tuning egr deleted head studded mpbr exhaust on 35s my ? what horsepower range Am I in? Next question on thinking about going with A different set up its 275/100 injectors with Jesse Warrens Dual HPOP and st472 turbo what horse power range would I be In with this setup?
05f250harley
190s and compounds should put you there on fuel. with whats in your sig you will also need a fuel system and a trans.:fordoval:
What turbos would you guys suggest with 190? I don't know much about turbos. I know I want 600hp. Do you guys think towing would still be possible with a setup like this?
Sent from my iPhone using Tapatalk - now Free
Mwilbur516
We 'be had several guys dyno at 600+ on fuel with 190/100's and our MTW Stage 3.
Derkperk
Twin cities
A barder or RCD 68 VGT, I think some guys are running a MTW stage 3. Sticking with a VGT for towing would be better.
03 tx pwr stroke
Texas
So what exactly would I need to hit 600 on fuel? I've been thinking about 225/100's and compounds. Looking for a complete parts list, ie rods, pistons, etc.
