faster6.0
- Joined
- Sep 27, 2011
- Messages
- 2,428
- Reaction score
- 0
Blue waffle u should be close to 700 On fuel as it stands!
i just got off the phone with Matt (robinson) and he said voltage is voltage regardless if it's tuned or not. my scangauge II is reading at least 4.15 volts so far.
He also said that going from 190/100 to 215/100 would not really net much power gain at all. The best thing I could do is jump to 150 nozzles.....but I'm fairly certain the stock pump wouldn't like that
What eric is saying doesnt even make sense, theres no way voltage can fluctuate there would have to be some interuption to the signal for that to happen... How would you know if you were losing hpop with a race tune if you cant test it on that tune besides using a mechanical gauge?
Ive seen 04 trucks read voltage perfectly fine when tune.
Yes Eric and some other tuners tune off the icp sensor, which reads in voltage, which will show a false icp voltage reading while running his tunes except on a mechanical gauge, essientially fooling the hpop/icp to make max volume/psi and hold it. Great way to make power
Just make sure you can maintain ICP. Or else your dreams will be gone until you get more oil lol
yeah I talked to Jared about that. I want as much fuel as I can get on stock oil...at least for now. we thought 215 would be about what I could support with the stock hpop....as long as it's healthy. i actually just programmed my scangauge a bit ago to read voltage so we'll see.
Chris at TSD said they had some good luck running 225 hybrids with a stock hpop.
Everyone tunes off the icp sensor, this is nothing new, my truck reads ICP just fine with Erics tuning, Chris and Matt's tunes, as well as Tony's. There is no reason why the voltage should be reading the way it is on some trucks. The only reason I can think is the fact that the 03-early 04 trucks use a difference PCM than the 04.5+. Im sending this to Matt R
I haven't ran Matt's tune in a couple months, but IIRC it didn't mess with my trucks ICP voltage. The tune from Eric that I currently am running does however, like Chris says. Just my experience.
