Derek@Vision Diesel
Well its hard to say because i still dont know what your running... Not to mention the stock transmission robs a lot of the power, so the wow factor kind of gets taken away
sounds like the engine light is an over boost code if it went away
There is no white or blue smoke. Im pretty convinced its just air in the system.
The injectors were all seated correctly and I torqued them down accordingly
Are you SURE you don't have a boost leak?? Check the manifold boots. They're easy to forget to tighten fully.
