SouthFlstrokin'
- Joined
- May 18, 2011
- Messages
- 6,068
- Reaction score
- 0
And yes its getting fuel to the bowl as I have 60 psi at idle, but my fuel pump could be weak though with 200k miles on it
There is no way for me to watch icp, the truck has more balls then it did before the chip, but I guess I expected more?
The chip works and I drive around on the highest setting. I've never ran gearhead tunes so I guess that's some getting used to also. I'm going to change the boost line to the gauge to see if that's part of the issue also because I noticed the line isn't correctly seated to the back of the gauge .
The tunes all work, high idle and up. I can hear the ipr work harder as im changing the tunes like my old dp tuner did years ago.
Guys I will say leaky orings will cause this problem new or not something could have happened. I had this happen to me and ICP and IPR readings were all still fine but I had no power. Changed the orings oiled them with STP and extremly cleaned all the injector cups with a q tip and the truck got its full power back plus some. Also I never notice a change with gearheads tunes from each tune. Also you are used the all the fuel at once feeling but you will notice matts tunes pull harder as boost comes in...
Yeah definitely true about the boost, if you dont have boost you dont have any extra fuel with his tuning
I suppose the injector O-ring deal could be the issue, though that is not as common as possibly a sticky IPR or a boost leak.
What kind of boost numbers were you seeing with the O-ring issue? Normal or below normal
Boost numbers were not much off because of the stock turbo. Put it this way we had two chips one with 7ms of pw and one with 3ms of pw and then you could tell there was a problem...
It was also romping, now the idle is much smoother.
Did you put a straight edge over them and make sure they were all seated? If so, did you pull the ICP sensor and fill the rail the best you could?
I would definitely do that, and then take the truck out, and get on the interstate, wait until your TC locks up, and drive with the most throttle you can without downshifting. Do that as long as possible.
