Is a GTX worth the extra coin?
SkySki Jason
N. GA Mountains
Now with this sealant seeing its the red loctite will i be able to take the fittings off if i need to? anyway looks like im going to look into this for my fuel system.
Don't confuse Loctite 545 THREAD SEALANT with the loctite thread locker you are used to seeing. THE ONLY similarity is the color.
The answer to your question is NO, the 545 does not make the fittings any more difficult to remove than any other type of THREAD SEALANT.
I have used this product on my fuel system's NPT fittings since 2006. Many parts were R&R'd when I rebuilt the engine after 120k miles since modifying fuel system - no issues with being tough to remove. I even had some brass (OMG!!!) fittings in the head, which are famous for failing and leaving parts in the head to be removed the hard way...
Seriously, this is the best product available for this application! No question about it. :toast: I also use Gasoila thread sealant, but typically only on larger fittings (1/2" up). This product is much more viscous (and therefore more effective) than any of the watery rector seal crap at the hardware/autoparts store.
vanderchevy18
Benton, Ks.
We use jet lube 550 here at work for these exact same scenarios. I know its antiseize, but it works awesome as a sealant and is petrochemical grade.
TARM
Yes this sounds much like the purple but with petrol based resistance. gives you seal and tension from back out but not a cured locked grip. On fire arms I was a master at coming up with very cool ways to use various forums of thread locker liquid gel paste etc..
TARM
I am not sure I like what you are alluding to there !?! LOL
