issues
kakorb
not that i know of but for $359 for the ford bundle if thats all i need i might be tempted if would help every car i own is a ford same with my parents so if i could read all ford obd 2 vehicles
kakorb
no $349 for the ae ford bundle is that a good deal? can u moniter stuff while your driving with an ae
kakorb
did replace icp and now it takes forever to start. havent tried unplugging it i will tonight when im home
hawgdoctor
king george, va.
Yeah 349 is a good deal. I love mine. You can monitor up to 9 parameters in a glance, and it will work while driving too. Just make sure your laptop has a good battery, or a good converter to tag along works too.
kakorb
i read you can reuse valve cover gaskets is this true or purchase some for standpipe dummy plug ck also is there any other gaskets from anything you have to move to pull covers that will need replacing
hawgdoctor
king george, va.
Yes they are reusable, just make sure they're clean when they go back on, and that would be all you would need to for the pipes/plugs.
kakorb
so bpd has stand pipes and dummy plugs for around 155 good for isurance? or clean and put o ring kit in what i have
kakorb
would the sct livewire display icp and ipr readings says datalogging monitering pcm data
kakorb
so im ordering the ae and ipr socket to pull and clean what should the values for the icp and ipr be when reading them also im gonna plug truck in tonight and see if starting issue is there dont think that will tell me much though
kakorb
if the truck is plugged could the ipr still be a culprit or spool valves sticking cause is fired up and idled up down for couple sec then settled in a 720 like always within 10 sec never stalled
kakorb
thats what elite diesel suggested but i got a power balance and they said there ok
kakorb
so i got my ae . icp volts between 1.04 to 1.19, icp pressure 759.1 to 888.3, ipr % 33.2
are these good values or bad i got codes for icp
kakorb
so i have not go values ive disliked for icp or ipr one time ficm read 38v on start and 40 but nver got that lower again nvr dips past 47.5 however i got b1342 code ecu is faulted should i be lookin to replace this or is the edge tripping this code
