20007.3L
Transmission codes?
None! Had it scanned at work today
Transmission codes?
delayed shifts? or shift flares? over reving?? if its just slamming gears it doesnt sound like you smoked it.
Not to hijack, but I just did the first 4x4 launch on the new setup in my truck. The trans is a built 4r100. But it made a loud bang and super hard shift and attempted to shift into OD. Now it wont shift into overdrive, and the fluid smells burnt. Any ideas?
Actually that is a complete full on hijackLOL
Delayed between 1-2nd then slams hard goin into 2nd. When i say slams hard, my teeth rattle when it kicks
You do understand that there is more to diagnosis than hooking up a scanner right?
generally when the VSS goes its blinks OD and you loose ABS... pull your VSS from the rear end and check for metal shavings. mine had some from the LS that collected to the magnet and caused it to read wrong.
My OD button doesnt work! Replace the switch still dont work!
Edit! The rear end?????/ What does that have to do with the trans?
