rear vehicle speed sensor that is on top of the rear axle tells the trans when to shift.. if its dirty or messed up it will wreak havoc on the trans...
You do understand that there is more to diagnosis than hooking up a scanner right?
its the quickest and simplest, but prepare for the worst...
if that aint it, your trans is fubar, do you know what FUBAR means? or tc is bad or solenoid pack is bad or everything is bad... if its shifting into all the gears and the tc is locking up more then likely its electrical, like vss or solenoids.
How hard was it slamming, this some b!tch makes my teeth rattle when it kicksmine was banging on shifts and the tc was locking up... popped the vss out and it had a bunch of chit on it. cleaned it off and put it back in.. fine ever since.
yup same way. i thought the same thing... might get lucky, might not...
Mine went out a couple months back, no forward gears whatsoever lol. Now I have a bts that i bought from a member on here and just need to get it put in when I feel like it. Maybe you will get lucky, but if not I would just drop the coin on a bts and be done with it.
alright 1 more question for you...Trans fluid smells burnt!? Its a light brown, not red. I am picking up a new VSS from work and transfilter and fluid from work tomorrow. any ideas why is burnt or whats causing it?
honostly i have no clue when the trans was servised last! i have my pod and gauges sitting on my kitchen table! Need to install those to see what the trans is running at!
