Large "factory appearing" Atmosphere results thread..
co04cobra
WV
71 that was pulled off
RCD 75
Morgans pretty ceramic coated heads :ford:
BP seems be down with some more power on mid and top end. Its hard to tell everything as I changed nozzles too, but I have yet to hit the WG.
Hoping to get on a dyno First of Jun.
webb06
Seneca, MO
RCD 75
Stock vgt?
2good2Btru
Houston, Tx
RCD 75
What nozzles did you go with?
Note 3
B585Ford
WV
That 75 is just beautiful.... The heads, they're not bad either. Glad it's all running good for ya!
I have searched for quite a while and have come up empty. Do you have any data on the 75 (with or without 59) on stock fuel or a thread where someone has the 75 on stock fuel?
forcefed6.4ford
Medicine Hat... Again
Just got confirmation my 75/59 will be shipping tomorrow or Thursday (finger crossed for tomorrow) and hopefully I will be able to tell you first part of next week.
johnp115
Southern MD/Charlotte NC
I've searched all over trying to find the same thing. Especially with a stock Vgt cause I want to know how it spools having that larger turbine. But I haven't found anything yet either. I may have it within a month or two and I'll definitely post results but hopefully someone has solid info before then.
i have a 73mm and it is hardly any more lag than stock.
Csilva187
I can't hardly tell a difference. Stock fuel, stock Vgt, 3000' roughly.
Athens, IL
The vgt controls the spool up. The vgt is what spools of the line not the atmo. A stock vgt is going to spool like a stock vgt, no matter what atmo you have (within reason). The atmo will come in after you've already made boost off the line with the vgt.
I don't know of any brand or size drop in factory housing compounds that don't spool well enough to drive and tow like a factory truck. Fwiw. May suffer a small amount of low end with a 59mm but it's not very noticeable at all.
B585Ford
WV
Good to know. Other than Riverside with a 59, this is the only other truck on stock fuel I have read about. Are you gated and what kind of EBP do you see at WOT (especially since you are on the stock VGT)?
Csilva187
After I get some electronic misc figured I hope to get some more wheel time. Big drop in egts, doesn't sound different, spools fine, and it'll move.
Edit- I will dyno in the next month like so unless I score a 59mm before hand.
